Re: Alternator for C113
Posted by tim11612 on August 12, 2014 at 13:36:56 from (32.217.81.223):
In Reply to: Re: Alternator for C113 posted by PretendFarmer on August 12, 2014 at 11:12:41:
ok,i take it you found the marks,flywheel and half moon cover plate and lined them up.on the distributor,i run the tractor,loosen the distributor,turn the distributor so tractor revs up,then just back off on distributor just a little bit,not much,doesnt take much,you can hear it even out.your good to go..
