Re: SuperC 6-12 volt conversion
Posted by Zwepper34 on August 12, 2014 at 15:03:36 from (216.46.151.14):
In Reply to: SuperC 6-12 volt conversion posted by Zwepper34 on August 07, 2014 at 10:31:44:
Hey guys I exchanged the original coil I bought for one that is aftermarket and does not require a resistor put it on and it fired up right away. I took the old resistor off and it was broken.... Guess i found the problem anyway resistors are 12 buck and the coil was 20 so I'm just going to go with the coil by itself to make things simpler thanks for the help
