Jimmy, I have set the F"s with the snap sound at TDC. Have done some with the head off so you can see when piston is TDC. Also the crank pin in front pully TDC when pin is horizontal. But still need to twick most of them some once runing. I get the best timing when running and I can find the sweet spot as it will run smooth at that spot not before and not after. Than you know witch way to move your timing. On most F"s if the flywheel has not been pulled and cleaned I can not see the flywheel timing mark. oldiron29
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
