Re: B414 Diesel Engine Troubleshooting Help needed..
Posted by T-Bonz on August 12, 2014 at 18:24:44 from (69.35.177.185):
In Reply to: Re: B414 Diesel Engine Troubleshooting Help needed.. posted by jimb2 on August 12, 2014 at 16:57:30:
Air cleaner is clean and is not the issue.. The tractor has never had glow plugs that function.. we always give it a tiny snort of ether when cold and it fires right up.. once the engine is warm it will start right up quickly without ether. The smoke cloud behind it is just miserable.. But seems to have enough power.. It just never runs smoothly like other diesels I have run.. always seems like a constant knocking from compression.. not a rod knock.. as I said it had a new short block and holds max oil pressure even when hot.
