Re: IH 400 Cylinder wear specs
Posted by pete 23 on August 12, 2014 at 19:27:35 from (74.33.76.1):
In Reply to: IH 400 Cylinder wear specs posted by husker44a on August 12, 2014 at 07:52:31:
A measurement of 4.125 would be the direct drop in thin wall sleeve that is the normal replacement sleeve for those engines since about 1958. If you can feel a ridge I would recommend replacement but of course it will work with your measurements unless it is scored. Have to be sure to measure pistons also as they often collapse some and give you more problems than the wear in the sleeve plus the top ring groove if most likely worn and need machining and a shim if reused.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
