Farmall h brake drums
Posted by Danh on August 13, 2014 at 03:26:04 from (67.237.11.166):
Restoring our 1940 farmall h. I took apart the brakes to replace the seals behind them. The brakes drums are soaked with oil on the back side. What and how is the best way took clean them up with brake clean or something else ?. Also the left side drum on the braking area is shiney and the right side is all rusty how can I clean it up ,can it be resurfaced ?
Thanks Dan
