Re: Stage 2 h or m hydraulics
Posted by Brian Schmidt on August 13, 2014 at 19:03:17 from (69.66.237.150):
In Reply to: Re: Stage 2 h or m hydraulics posted by Ron McQuigg on August 11, 2014 at 19:08:23:
Ron,
One other thing I just remembered. The regular H gas tank may not work depending on the hydraulic unit location. If you use the stock SH location, the fuel sediment bowl will interfere. You will either need to get a late SH tank (almost impossible to find) or cut the bottom of the H tank sump out and move it to the position of the SH. Make sure the tank is clean and gas vapor free when doing that work!!!
