Re: M 12v conversion
Posted by Trevor H on August 13, 2014 at 19:14:13 from (70.209.4.11):
In Reply to: M 12v conversion posted by BigJoe33 on August 13, 2014 at 17:58:48:
I just converted my M to 12 volt.
I had the Alt shop build a Delco 10SI and put the smallest pulley they had on it. He told me he set the alt up to make power at 600 RPM or above. it makes 14.7 volts at idle
1 custom mount
1 slightly longer alt belt
1 12V coil with built in resistor
and a simple switch to give power to the coil
my wire harness on the tractor is only two wires
1 from alt to battery +
1 from battery + to switch then to coil.
You can also buy a new 10si from napa for about 60 bucks
Let me know if you need any thing else.
