You need to determine if the drive shaft and countershaft are both turning when this happens. Problem is this can be dangerous. You have to take bottom cover off behind belly pump and when this happens find out if one or both are turning. Mount a mirror underneath so you can see the shafts while you are still in operating position to be able to safely control the tractor. This will tell you if clutch is problem or inside transmission.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
