Re: PTO HYD PUMP ???
Posted by T_Bone on December 31, 2000 at 18:55:08 from (207.254.52.128):
In Reply to: PTO HYD PUMP ??? posted by todd on December 31, 2000 at 16:08:59:
Hi Todd, The "in" is the suction side, the out is the pressure side of the pump. The screw probablly adjusts pressure and is set at the factory for maxmium safe orperating pressure of the pump. Although the pump can put out more presure, doing so will over work the pump, shorting the life of the pump. Good to here your tractor is running great.
T_Bone
Post A Followup
: Re: Re: PTO HYD PUMP ???
