Re: Farmall M Stops moving/PTO while mowing
Posted by D Slater on August 14, 2014 at 05:26:40 from (184.14.176.27):
In Reply to: Farmall M Stops moving/PTO while mowing posted by Trevor H on August 13, 2014 at 18:36:53:
If tractor has a belt pulley gear box, put it in gear when using the tractor. If it also stops turning its a clutch problem or something ahead of the transmission. If it doesn't stop turning it may be a retaining failure of constant mesh gear to countershaft. Although unlikely to start pulling again unless galling.
