Re: Farmall H generator help
Posted by chad from michigan on August 14, 2014 at 07:51:03 from (151.163.2.113):
In Reply to: Re: Farmall H generator help posted by John T on August 14, 2014 at 06:11:22:
John
It is 4 wire there is one on the opposite side all by itself and its wires to the genny.
The other side has "L" "BAT" and I think "F"
when I got there Dad had the "L" terminal hooked to the old feild wire on the light switch.
"BAT" was hooked to ammeter and "F" was hooked to the genny. The other side was also hooked to the other post.
So the "L" is for lights? This tractor doesn't have lights anymore so I wont hook that up to anything. The shop had polarized it for my dad. I also polarized it when I got there. when Dad had the old feild wire on the "L" and the ammeter went total negative. I will ask My dad to call and find out if it was polarized for negative ground becasue our tractor is positive ground.
