Re: Farmall M Stops moving/PTO while mowing
Posted by Trevor H on August 14, 2014 at 08:19:41 from (166.147.120.167):
In Reply to: Farmall M Stops moving/PTO while mowing posted by Trevor H on August 13, 2014 at 18:36:53:
I mowed about 2 acres with it this am and I can duplicate the problem in 1 2 and 3rd gear. It does not have a pulley gear box so I can't do that test. Over the last 30 mins of mowing when it stops moving I can step on the clutch real quick and shift into neutral by the time the mower stops spinning I can go back into gear with out even dis engaging the pto and continue on.
I have do a lot of clutches in cars and trucks. Never done one in a tractor. I would assume that splitting the tractor so I can surface the flywheel is the best way to go.
Or would you just drop the pump and change only the clutch?
Thanks for all the comments I appreciate the help!!!!
