Re: Farmall M Stops moving/PTO while mowing
Posted by kevinj54 on August 14, 2014 at 12:03:23 from (162.17.149.81):
In Reply to: Farmall M Stops moving/PTO while mowing posted by Janicholson on August 14, 2014 at 11:59:26:
I think is a key, had mine off before to change the seal too.
If the flex coupler is good things should not have too much movement in there but it may be worn or have broken or missing bolts also.
