Re: What did I do wrong? Farmall H carb leaking fuel
Posted by D Slater on August 15, 2014 at 04:36:28 from (184.14.176.27):
In Reply to: What did I do wrong? Farmall H carb leaking fuel posted by Redturbo on August 14, 2014 at 21:55:52:
You didn't say if the engine started. Common for gas to be drawn up when cranking then when the cranking stops to fall back into the carburetor throat.
