Re: What did I do wrong? Farmall H carb leaking fuel
Posted by Gmitch on August 15, 2014 at 09:12:46 from (72.161.238.50):
In Reply to: Re: What did I do wrong? Farmall H carb leaking fuel posted by Redturbo on August 14, 2014 at 21:57:06:
The VERY first thing I would have done when I noticed the gas drip is rap the side of the carb with my pliers. Sometimes that loosens up stuck floats, etc.
