Re: What did I do wrong? Farmall H carb leaking fuel
Posted by rumplestiltskin on August 15, 2014 at 13:35:54 from (97.91.22.177):
In Reply to: Re: What did I do wrong? Farmall H carb leaking fuel posted by FBH44 on August 15, 2014 at 02:19:43:
Also, make sure the float isn't hanging up on the gasket. Trim the gasket if necessary.
Mark W. in MI
