Re: Farmall M Stops moving/PTO while mowing
Posted by Trevor H on August 15, 2014 at 15:50:45 from (24.127.240.73):
In Reply to: Farmall M Stops moving/PTO while mowing posted by Trevor H on August 13, 2014 at 18:36:53:
The clutch pedal is all the way back to the plate at all times. The linkage rod is close to max length for adjustment but the pedal free play is about 3/4 of and inch.
I am well versed on how this tractor/pto works. When I am mowing everything it working like It should, all of a sudden everything stops....tractor stops moving and pto stops spinning.... like the clutch was pushed. I can't feel it slip and no unusual noises/ vibrations. If I then push in the clutch shift into neutral AND let off the clutch THEN push the clutch and shift back into gear the tractor and pto start operating as usual again.
