Re: Farmall M Stops moving/PTO while mowing
Posted by Trevor H on August 15, 2014 at 16:01:54 from (166.147.120.154):
In Reply to: Re: Farmall M Stops moving/PTO while mowing posted by John M on August 14, 2014 at 13:02:13:
This post is exactly correct. Everything stops just like you pushed the clutch all the way in but I did not the clutch is all the way back to the plate and nothing is happening. At this point if I push in the clutch and shift to neutral let the clutch back out I can then push the clutch back down shift back into gear and let off the clutch and everything operates like normal again for approx 10 minutes then I happens again.
