Re: Buying a Farmall
Posted by ken house on August 15, 2014 at 20:07:47 from (173.242.240.3):
In Reply to: Buying a Farmall posted by _Mark_ on August 15, 2014 at 17:24:47:
the B is probably the easiest to get on and off. add a step, in front of right rear tire. or if it has a drawbar, add some expanded metal so feet will not be as likely to slip.
a is hard to settle in behind steering wheel.
c, h and m are too tall.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
