Re: Buying a Farmall
Posted by NNP on August 16, 2014 at 05:29:32 from (66.66.112.196):
In Reply to: Buying a Farmall posted by _Mark_ on August 15, 2014 at 17:24:47:
IMO, Super C would be the best tractor for puttin around,
but usually expensive.
An H would be almost as good, a little bigger in tight quarters, but very cheap to buy.
Either, set up with the horseshoe shaped hitch would be easy to make steps.
A non-slip flat metal plate bolted on top of the axle for the final step works well.
Seeing he had an H, I'd probably get that.
Either, completely enclose the pto shaft, or securely lock the engagement lever off with a bracket, etc.
The steps will be right there......
You didn't mention his height, Farmall A's and B's and Allis B's and C's were made for miniature people I think. tough to get on and off, and your knees are too high when seated, and the seats are much too low....and I'm not 83.....
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
