Well, one thing is for sure, you don't have a "clutch problem". I think you're going to find either a transmission pilot bearing failing allowing the input shaft mowing forward & back and letting the constant mesh gears get out of engagement, or the lower transmission shaft getting loose in the bearings in the trans. The M had a splined lower shaft where the H has a keyway the full length of the shaft, the gears can move around and get into & out of alignment.
I'd pull the plate off where the belt pulley would attach and push/pull/pry around on various gears and I think you'll find your problem. I would think you're risking greater damage to your M by continuing to run it.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
