Re: ihc 400 hy leak
Posted by Brownie 450 on August 16, 2014 at 13:10:28 from (66.43.241.198):
In Reply to: ihc 400 hy leak posted by jim_uny on August 16, 2014 at 11:47:52:
Likely the o-rings on the steel lines from the pump.
There are 3 nuts that hold the plate on that end, & 3 bolts on bottom of the pump. 2 o-rings on each end.
