Re: Farmall M Stops moving/PTO while mowing
Posted by pete 23 on August 16, 2014 at 14:41:48 from (173.87.12.198):
In Reply to: Farmall M Stops moving/PTO while mowing posted by Trevor H on August 13, 2014 at 18:36:53:
The reason I said to use a mirror to look at the shafts is due to the fact I don't want to tell him to crawl underneath when this stoppage occurs. He may not have it in neutral and get run over. If I was there I would simply take that lower cover off behind belly pump and look at the shafts. Then you will know problem is inside or outside. I have seen the counter shaft break in a super M one time and it did all kinds of things. It broke inside the gear so some things worked and others didn't. Fact is learned a valuable lesson because I pulled cover and could not find a thing wrong. Put it back together and then found out the gear on shaft would move back far enough to press on the cross shaft brake pedal operates and brake lever would bind. Had to dig in deeper to find a problem.
