Re: Farmall wont start
Posted by Nate V. IA on August 16, 2014 at 16:51:27 from (216.51.200.109):
In Reply to: Farmall wont start posted by mjp9348 on August 16, 2014 at 16:32:53:
Sounds like you need to go thru the carb again. Are you getting good suction thru the carb? Take the air cleaner pipe off at the carb, hold your hand over the hole, turn the engine over. It should suck you hand in.
Or if the cylinder walls are dry you might need to squirt some oil in the spark plug hole to help seal the rings.
Nate
