Re: my 400 has antifrreze in the oil. pull the oil pan or not
Posted by mike1972chev on August 16, 2014 at 18:13:53 from (108.67.92.43):
In Reply to: Re: my 400 has antifrreze in the oil. pull the oil pan or not posted by SDE on August 16, 2014 at 11:36:53:
If you have access to a coolant system pressure checker,you can add a few (And I MEAN ONLY A FEW) pounds of pressure on the entire cooling system. and it will help in the process of finding the leak.Like I say,DO NOT over do it! Get underneath the crank case with a good light and start carefully looking.
It should help to show it with out the need of the engine "warmed up". ;)
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
