Posted by mjp9348 on August 16, 2014 at 20:58:21 from (50.129.238.21):
In Reply to: Farmall wont start posted by mjp9348 on August 16, 2014 at 16:32:53:
I went over the carb 4 times since the major overhaul of the carb (everything inside the carb has been replaced new to spec per instructions) and the engine . I took the manifold off and resealed the manifold , the carb .. It has no suction . No leaks from the tractor head or anything ...
I pulled the plugs today and checked to see if it was spitting any water or fluid , and it was dry ..
The tractor is definitely a H , the roller bearings are on the piston shaft , they are plates that the cam spins inside of ..
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
