Re: my 400 has antifrreze in the oil. pull the oil pan or no
Posted by NNP on August 17, 2014 at 07:17:09 from (66.66.112.196):
In Reply to: my 400 has antifrreze in the oil. pull the oil pan or not posted by SDE on August 16, 2014 at 10:40:47:
agree
pulling the pan is usually first and easiest.
takes patience and a few days sometimes, but you will find the leak.
good time to pull a rod cap and see how much damage that antifreeze did to the bearings if it was ran at all.
even with dry sleeves, ya never know till you look.
recently had one with a cracked sleeve, with a matching block crack under the sleeve = antifreeze in the oil.
