Posted by mjp9348 on August 17, 2014 at 11:41:49 from (50.129.238.21):
In Reply to: Farmall wont start posted by mjp9348 on August 16, 2014 at 16:32:53:
So I did a compression test , sitting at 90psi for all four cylinders . Yesterday I fixed the manifold and it wasn't pulling in any air , today its pulling air like no other ... so we are good on that aspect ..
I sprayed starting fluid on the manifold and the head while someone else was cranking to look for other leaks ? None , it didn't start ..
I sprayed the carb with starting fluid while someone else cranked and it started and burned the fluid but was backfiring out of the carb , shooting flames, I know yesterday when I was actually giving it a spray through the air intake it would back fire a huge majority of the oil in the canister out the top of the air intake cap . .. I just put new plugs in it before I did all this today and I pulled them out to see if they were wet , and still dry as a bone ...
When I rebuilt this carb I replaced everything inside the carb I bought a major rebuild kit .. I have tried to adjust the fuel adjusting needle , and the idle needle , but no difference no matter all the way open or closed .. the plugs are not getting fuel ..
I suppose I will open this carb up again , but is there anything I should look for or change , I really went to town on this carb and its not my first ever rebuild I have done it a hundred times before on a bunch of other engines ... Any help is Much appreciated .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
