Re: c113 valves
Posted by pete 23 on August 17, 2014 at 15:25:27 from (173.87.12.198):
In Reply to: c113 valves posted by calcubman on August 17, 2014 at 11:21:49:
You need to use the same length valve you have. The longer one is for gasoline engine and shorter is distillate. The spring tension would be way off and your rockers would not contact tip properly.
