Re: super a oil pressure
Posted by El Toro on August 17, 2014 at 17:21:09 from (96.244.7.206):
In Reply to: super a oil pressure posted by henhawk1969 on August 17, 2014 at 13:08:33:
I wouldn't run the engine until you find the problem. The oil line may be plugged, I would
look for a pipe plug into the oil gallery and install the pressure gauge there. Just use the starter to spin the engine over to see if there's pressure on the gauge. If there's no pressure I would pull the oil pan & pump. The relief valve maybe stuck open. Hal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
