Re: Farmall wont start
Posted by mjp9348 on August 17, 2014 at 17:30:38 from (50.129.238.21):
In Reply to: Re: Farmall wont start posted by kevinj54 on August 17, 2014 at 16:14:57:
The engine ran probably 10 years ago ... Throw parts at it , No , I am a mechanic I just don't throw parts at it ... The number 1 and 3 pistons were seized to the sleeves , I tried for weeks to unfreeze it and it was solid , I ended up replacing all 4 pistons and sleeves along with rebuilding the carburetor and replacing the coil because it was burned up .
I think I figured out what the problem is with this tractor , I noticed today as I was setting the rockers , that there was a piece of metal in the manifold that was broken off .. I am assuming the engine is pulling gas but its shooting out the exhaust when I am cranking when I do shoot it with starting fluid it grabs enough to ignite but its blowing back through the carb as well as the exhaust .. Its just a theory .. but the piece of metal I did pull out was almost 2 inches long by 1/2 inch wide and looking like a piece of the pipe , not build up from years of running .
