That's the place I was posting about in the first post. Yes there is a splined coupling that joins the clutch shaft and the t/a sun shaft. Maybe when you split the tractor you moved the clutch shaft forward enough for the coupling to fall off into the bottom of the t/a clutch compartment. Can't remember if normally the shaft will move forward enough for the coupling to fall out with the pto drive gear in place though, unless something else give. If there's no coupling look in the bottom for it or pieces of it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
