Posted by NNP on August 17, 2014 at 20:55:48 from (66.66.112.196):
In Reply to: super a oil pressure posted by henhawk1969 on August 17, 2014 at 13:08:33:
I'm with eltoro, no more running til you find the problem, especially with an engine that has been sitting.
Get a hand crank, take the plugs out, take the oil pressure gauge right off. Don't start it again until you can get oil puking out the gauge hole by hand cranking.
I'd just pull the pan, probably needs cleaning anyway.
possible causes with pan off,
El Toro's relief tip
oil pump bottom plate gasket blown out completely.
completely plugged screen.
intake pipe broken or detached.
and not likely, but I just had one.....oil pump or cam oil pump drive gear teeth sheared off. (mine was the cam gear teeth sheared off)
Pulling the oil pump and after repairs, sticking it in a pan of oil and turning the gear...ok it works.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
