Re: Farmall M Stops moving/PTO while mowing
Posted by Owen Aaland on August 18, 2014 at 03:55:20 from (216.47.34.49):
In Reply to: Farmall M Stops moving/PTO while mowing posted by Trevor H on August 13, 2014 at 18:36:53:
When the tractor stops moving and the PTO quits, try shifting into 5th gear without touching the clutch or PTO shift. If it grinds and the PTO is still not working the problem is internal to the transmission lower shaft. If it goes into 5th without grinding the problem is between the clutch and transmission.
