Re: Farmall M Stops moving/PTO while mowing
Posted by mkirsch on August 18, 2014 at 05:26:29 from (65.199.189.6):
In Reply to: Farmall M Stops moving/PTO while mowing posted by Trevor H on August 13, 2014 at 18:36:53:
Why don't you guys think it's the clutch?
It sure sounds like the clutch to me.
If it were internal to the transmission there would be some sort of clatter or grinding or ka-BANG!, and it would happen exactly ONCE.
The clutch is slipping all the time, gets hot, and won't hold anymore. Give it a few minutes to cool and it will hold again for a while. Of course it will run longer from cold because it takes time for heat to build up. Just sitting there for 5-10 minutes only lets some of the heat dissipate.
It doesn't do it when you're not mowing because the mower puts a tremendous load on the drivetrain!
There's no way to know for sure what's wrong until you start taking things apart. You don't have X-ray vision. We don't have X-ray vision. Time to get the wrenches out and get busy.
My recommendation is that you drop the belly pump and pull the clutch through the bottom. If the clutch is indeed shot, you can then split the tractor and resurface the flywheel if you think it's necessary. Otherwise, you haven't put a whole lot of effort into tearing the tractor apart unnecessarily.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
