Re: Farmall M Stops moving/PTO while mowing
Posted by rustyfarmall on August 18, 2014 at 10:49:27 from (208.126.186.41):
In Reply to: Farmall M Stops moving/PTO while mowing posted by mkirsch on August 18, 2014 at 07:08:53:
If I weren't in the process of dismantling an H transmission, I might agree with you. The main input shaft has a gear on it that meshes with another gear internally, and that is what drives the whole thing. If one or both of those gears is damaged and chewed up, as mine is, it is very possible for those two gears to slip.
