Spring and fall are usually worst problem around here because there is enough humidity in the air and temp falls in the correct range for freeze up. In the winter air is usually too dry to hold enough water BUT, big exception, if bucking snow or it is snowing out that will put enough moisture in the air to really freeze them even at higher speeds. The heat stove around the muffler and leading into the air cleaner really works good to cure that problem. I see them manifolds with cakes of ice on the outside so you know wht is inside also.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
