Posted by tom orlando on August 18, 2014 at 12:38:39 from (100.1.52.109):
Hey Guys, I just finished putting my 1939 Farmall A back together and I wired it up this weekend. It is all converted to 12 volt, alternator,regulator,etc. As soon as I hook up the battery the starter begins to crank without the ignition switch being touched. I disconnected the small wire from the switch to the solenoid thinking I might have miss-wired something and got the same results. It has a three terminal solenoid two heavy terminals (one to the battery and one to the starter) and the small switch terminal which goes to the "s" terminal on the ignition switch. with only the two heavy terminals hooked up the starter cranks as soon as you hook up the other battery cable so I figured the solenoid contacts were stuck together. but when I remove the solenoid and check for continuity across the two terminals with an ohm meter I get an open circuit. I then tried another solenoid I had laying around and it does the same exact thing. so, either both solenoids are bad, both check open when checked with an ohm meter, or I"m out of ideas. before I go shell out $25 for another solenoid does anyone have any ideas on whether there is another test I can do on the solenoids to se if they are bad? I sent a couple of pictures for reference
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
