Re: KEEP AN M RUNNING
Posted by old on August 18, 2014 at 15:16:18 from (209.86.226.60):
In Reply to: KEEP AN M RUNNING posted by RICK IN VERMONT on August 18, 2014 at 15:08:11:
First off an in line fuel filter is likely to cause problems since most are made for fuel systems wit ha pump. Good chance you did not clean the carb as well as it needs to be cleaned. You have to soak a carb 24 hours and use a small wire etc to poke out all the passage ways and also blow them out and spray them out with carb cleaner. I use a torch tip cleaner tool to poke out the passage ways
