It should unless the valve is only doing it part of the time. Like say it is sticking part of the time, but only at a normal running RPM. A situation like that would perhaps give you a normal compression test reading. If a low compression test, put a squirt of oil in the plug hole and then re-do test. If the result is a normal reading after being low, it is a problem with the rings. If it is low after being low it is a problem with valves most likely, but a chance of cracked head or bad head gasket.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
