Re: What did I do wrong? Farmall H carb leaking fuel
Posted by Redturbo on August 18, 2014 at 21:32:32 from (66.112.187.143):
In Reply to: What did I do wrong? Farmall H carb leaking fuel posted by Redturbo on August 14, 2014 at 21:55:52:
Its not oil leaking from the coolant plate. Its permatex #2 that drooled out the bolt holes. The bolt is kinda rough shape, figure that would kinda help with any coolant leaks.
