Re: 300 utility run away throttle update
Posted by mkirsch on August 19, 2014 at 04:54:05 from (72.45.143.81):
In Reply to: 300 utility run away throttle update posted by corona boy on August 18, 2014 at 20:10:28:
What do you mean "governor hooked up or not?"
The governor can't NOT be hooked up to the carburetor, if everything is installed properly.
A 300's governor is the same torsion bar type as an H or an M. There is a tab on the end of the torsion bar and a slot in the front of the carburetor. The tab has to fit in the slot, or you will get weird governor behavior depending on which side you missed it by. Either it will rev uncontrollably, or it will not rev up at all.
