Re: Stuck Valve Super A
Posted by ken house on August 19, 2014 at 06:37:36 from (173.242.240.3):
In Reply to: Stuck Valve Super A posted by henhawk1969 on August 19, 2014 at 05:48:29:
i have to believe that valve is stuck open. remove side plate, spray with penetrating oil; remove spark plug, use hard wood dowel or screwdriver or some other and insert through spark plug hole onto the top of the valve and gently tap the dowel with a hammer. with good luck the valve will move. do not rush, take time, keep spraying with penetrant. turn engine over and repeat.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
