Re: Stuck Valve Super A
Posted by gene bender on August 19, 2014 at 11:31:46 from (67.55.226.121):
In Reply to: Stuck Valve Super A posted by henhawk1969 on August 19, 2014 at 05:48:29:
The valve is stuck open correct. Remove the valve cover then you can use some spay of any kind on the stem. You should be able to gently pry it up go easy DO NOT TAP IT DOWN as there is a little hair type clip on the stem to keep it from dropping down. A little tapping and prying it should come back up. When you get it back up use a rubber type hammer and tap it a little then pry back up after a few times it should free up. That has worked for me on the same head you have. If you cant free it up you will need to remove the head. good luck.
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
