Re: Stuck Valve Super A
Posted by henhawk1969 on August 19, 2014 at 11:52:55 from (208.180.143.16):
In Reply to: Re: Stuck Valve Super A posted by ken house on August 19, 2014 at 05:59:11:
It is the first valve back from the radiator. It has come loose from the rocker arm. You can put all the adjustment from the set screw in and it is still loose.
