Re: 504 stalling underload and popping sound?
Posted by glennster on August 19, 2014 at 14:36:20 from (162.204.229.223):
In Reply to: 504 stalling underload and popping sound? posted by Larry Zuefle on August 19, 2014 at 09:29:27:
poping from the carb or exhaust? could be the valves need to be set. if fuel and timing and spark are good, run a compression test and see if all the cylinders are within 10%. also check the distributor bushings for wear. pull the cap off and wiggle the distributor shaft side to side and look for play. if excessive, it will need bushings.
