There was some slack in the 4 bolt clutch joint. All the bolts were tight just some side to side play.
The trans input shaft still has the keyway/key so not an issue there.
I had to call it quits there. I will have the clutch out bright and early tomorrow morning to check it out.
With the pump out I did notice that when the clutch pedal is pushed all the way down it only moves the throw out bearing approx 3/8 of an inch. It does release the clutch disk though.
I also found a fine thread bolt approx 3/8 diameter in the small hole just below the rear main seal behind the flywheel. I can't get the bolt out of the hole I can only assume this is a rear main seal cover bolt??????
I am most likely going to split the tractor to find out where the bolt came from/ surface flywheel and clutch work.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
