Re: Farmall A - firing order [hooking up missing plug wires]
Posted by gdtractor on August 19, 2014 at 19:51:45 from (108.68.182.104):
In Reply to: Re: Farmall A - firing order [hooking up missing plug wires] posted by wayne in mn on August 19, 2014 at 05:57:38:
Sending to several responders .. i appreciate the help SOOOO much ..
Gary
YOu are EXACTLY RIGHT >> I shined a flashlight down on the cylinder and turned the engine on #1 cylinder to the TOP .... and the distributor rotor is exactly on the upper right (#1 ) ...
Now ... the bottom right from sitting ON THE SEAT would be #3 and bottom left would be #4 correct?
Top left would be #2 ? right?
THANKS So MUCH !!!!
Gary
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
