Re: bosch VE pump timing ih case 595 tractor
Posted by T in NE on August 19, 2014 at 20:04:16 from (75.235.111.131):
In Reply to: bosch VE pump timing ih case 595 tractor posted by 151 on August 16, 2014 at 19:26:30:
What's that got the 4B engine? The 6B with the VE, you need to get number 1 to TDC, then lock the pump down, before pulling it. Then either don't move the engine, or make sure it gets back to #1 TDC, before reinstalling the pump. Hang the pump from the mounts, tighten the gear down, tighten the pump down, and you're timed. The timing marks on the B series are unique to each pump/timing cover, they punch it in with a chisel once the pump is mounted.
